Exporting plume head/nose data from Fluent to either MATLAB or EXCEL
Old   July 30, 2018, 11:41
Default Exporting plume head/nose data from Fluent to either MATLAB or EXCEL
London
Studentt is on a distinguished road
I have created a two phase flow model using fluent. It is a tank with dimensions 3m (length) x 0.3m (height) x 0.15m (width).
I have created a lock release system, with 0.4x0.3x0.15m of saline solution at a density of 1.03 kg/m^3. The rest of the tank is normal water with density 1 kg/m^3.
The simulation works and all is well with the setup etc... however:
I want to extract the exact values for the head/nose of the saline plume as it propagates into the water?
Also, I have introduced small 0.2x0.2x0.05m objects into the tank on one side, to model the interaction when the plume hits the objects. I need to extract the values of the height of the saline solution as it hits the objects?
I am not familiar with MATLAB, so some basic explanation would be needed if anyone thinks I would have to use this program? But I'm thinking somehow I can extract the data from fluent itself and then create graphs on excel?
I would appreciate all help!!
Cheers
(attached is an image of the tank!)
Studentt is offline   Reply With Quote
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Easy way for exporting data from fluent seyedashraf FLUENT 2 February 19, 2016 05:20
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Exporting fluent case data to Ensight/paraview aerogt3 FLUENT 8 May 7, 2012 10:15
Exporting Fluent vector data into Paraview JT FLUENT 2 December 29, 2008 19:09
