Write Profile Variable File Name
Old   July 27, 2018, 15:46
Default Write Profile Variable File Name
AKulkarni is on a distinguished road
I would like Fluent to write a profile file for the temperature on the wall at the end of every time step. I am using the execute commands option to try and write the profile every timestep. The command I am using for write profile is as follows: //file/write-profile filename.prof surface_name and then I have blank commands entered in the execute commands dialog box to skip naming additional surface names and then a command that just says what variable I want to write a profile for (temperature). The problem I run into is that I want to index the filename every timestep so it is easy to keep track off. For this, I have tried the ti-menu-load-string(format #f "file~01d.prof" delta-time") command instead of the "filename.prof" as earlier mentioned. But that doesn't update the variable as it should. Any recommendations on how I should get it to update the filename every timestep? Thanks.
AKulkarni is offline   Reply With Quote
Old   July 28, 2018, 02:51
Lucky
Use () to end a list
Old   July 30, 2018, 10:49
I'm not sure what you mean. Could you please elaborate? Thank you.
file writing, macro, profile boundary cond., profile files, scheme
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
