flame velocity problem ?
Old   July 27, 2018, 04:36
Default combustion ..............flame not achieving the desired velocity ?
sooraj546 is on a distinguished road
I am trying to replicate the simulated combustion of methane through fine tubes(16 mm dia) into a combustion chamber but in my case my flame are not attaining the desired velocity contour compared to the developed model
i dnt know where i have gone wrong.........
models used
1. species transport-volumetric- diffusion energy source- -eddy dissipation model
2. air velocity 141.75 m/s temp 566 K
3. fuel velocity 14.19 temp 295 K
4. standard k-epsilon with std wall function
6. Radiation- discrete ordinate model.
the velocity which i am supposed to get are as shown in vel actual.jpg and what i am getting is shown in vel.jpg ?
Kindly help me out guys
Last edited by sooraj546; July 30, 2018 at 01:39. Reason: no replies.................
sooraj546 is offline   Reply With Quote
Old   July 27, 2018, 10:48
Laura
biond8 is on a distinguished road
Hi, I simulated methane combustion and I used the finite rate/ No TCI model with k-e RNG with autoignition, cause I wasn’t able ti decide starting combustion parameters in the eddy dissipation model. Did you validate your combustion model with experimental data?
biond8 is offline   Reply With Quote
Old   July 27, 2018, 10:54
I am trying to replicate an already simulated combustion model (developed using eddy dissipation ) still i am not getting the desired velocity.
The only reason in am using eddy dissipation is because i need to validate and replicate it first
Thanks a lot for your reply ! really appreciates further comments
Old   July 27, 2018, 11:06
Laura
I see.. I used also inlet diffusion option, if you would like to try! I’m sorry not to be helpfull
Old   July 27, 2018, 13:37
i have already tried with inlet diffusion......! still nothing................. thanks a lot for replying
combustion chamber, eddy dissipation concept, methane-air, species transport model, velocity contours
Wrong initial particle velocity in my air-blast-atomizer problem...? gaghane FLUENT 0 December 4, 2014 07:57
problem with velocity magnitude and vectors Hayder Mohammed FLUENT 0 August 12, 2013 03:04
problem with velocity magnitude and vectors Hayder Mohammed FLUENT 0 August 7, 2013 04:08
Pressure Velocity coupling problem Sunho park OpenFOAM Running, Solving & CFD 0 August 4, 2010 01:22
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
