tecplot: read UDM variables from fluent data files |
DS
Rep Power: 10 ![]() |
Good morning,
I'm Denis and I would ask an information about Tecplot. I open the fluent cas&data files in tecplot and I read all common variables as Pressure, Velocity and so on with the correct values. Unfortunately I couldn't read the correct UDM variables. In particular I just find UDM-0 UDM-1 and so on, and not the correct name assigned with "Set_User_Memory_Name" function and the value of these variables is zero everywhere. Can someone help me to understand how to solve this problem? Thank you very much Best regards Denis |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Help: Errors when using Tecplot to read a .dat datafile!! | bhbuaa | Tecplot | 0 | December 30, 2016 16:51 |
Tecplot 360 2013 Non Zero Velocity at the Wall with FLUENT data | LeDude | Tecplot | 3 | July 28, 2014 18:11 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
read data files and export to avs file | Santhosh | FLUENT | 0 | June 15, 2006 06:46 |
