LES diverging
Old   July 20, 2018, 19:39
Unhappy LES diverging
Florent Colomb
FlorentC is on a distinguished road
I'm trying to run a transient calculation on Fluent v17 to study acoustics around an airfoil exposed to a free stream of Mach 0.5. This tutorial about acoustics around a cylinder advises to use LES turbulence model with Smagorinsky-Lilly option along with Fluent's PRESTO! discretization for pressure, and 'fractional step' scheme for pressure-velocity coupling. These settings make my calculation diverge and I can't find a solution. I expect PRESTO! and LES settings to provide me better results than respectively second order discretization and laminar settings so I would like to have the calculation converging with these.
Calculation is pressure-based, air is ideal gas, airfoil is a no slip wall, the mesh is o-grid with a far-field pressure condition, time-step size is 1e-4s but going down 1e-6s doesn't make it either. The calculation is initialized using steady-state data obtained with second order and laminar settings.
The fact that my case is compressible when the tutorial is incompressible may play a role too.
FlorentC is offline   Reply With Quote
airfoil, converging, fluent, les, presto!
Diverging Temperature in LES - which settings to adjust? knuckles OpenFOAM Running, Solving & CFD 1 March 7, 2016 15:32
Grid difference between wall modeled LES and wall resolved LES hityangsir Main CFD Forum 9 April 17, 2015 12:59
OpenFOAM LES capability questions siw OpenFOAM Running, Solving & CFD 3 January 6, 2015 09:50
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
