Segmentation fault when calling F_T using c_face_loop
Old   July 19, 2018, 10:41
Default Segmentation fault when calling F_T using c_face_loop
Ben
bensciens is on a distinguished road
I've been trying to write a FLUENT UDF which cycles through all the cells in my FLUENT case. For each cell I want to loop over all the faces and calculate something using the face temperature. However, when the code reaches 'temp=F_T(f,tf)' I get a segmentation fault. I'm fairly new to the UDF stuff so I'm struggling to find the error.
I am trying to make this work on FLUENT 17.2 and the case models the transonic, viscous 2D flow over the NACA0012 aerofoil. Here is a minimal code example which throws the segmentation fault:
#include "udf.h"
#include "mem.h"
#include "sg.h"
#include "math.h"
DEFINE_ON_DEMAND(shock_viscous3)
    Domain *d;
    cell_t c;
    Thread *tf;
    face_t f;
    Thread *t;
    int n;
    real A[ND_ND];
    real f_visc, temp;
    d=Get_Domain(1);
    Message("Entering loop\n");
    thread_loop_c(t,d)
    {    // looping over cells
        begin_c_loop(c,t)
            f_visc= (C_MU_L(c,t)+C_MU_T(c,t))/C_MU_L(c,t);
            if (f_visc > 15.0)
                c_face_loop(c, t, n)         /* loops over all faces of a cell */
                    f = C_FACE(c,t,n);
                    tf = C_FACE_THREAD(c,t,n);
                    Message("Temp\n");
                    temp=F_T(f,tf);
                    Message("After Temp\n");
        end_c_loop(c,t)
Any help would be greatly appreciated.
bensciens is offline   Reply With Quote
Old   July 19, 2018, 15:53
Lucky
Did you declare temp in the UDM beforehand?
fluent, fluent - udf
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
Segmentation fault in SU2 V5.0 ygd SU2 2 March 1, 2017 05:38
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
