July 15, 2018, 19:17 |
Data center simulation in Fluent
Dayananda KM
Rep Power: 8 |
I am trying to simulate air flow and temperature distribution in fluent. But i am having problems while specifying boundary conditions.
For servers in a rack , i modeled as blocks. air needs flow through servers. Here is the problem, how to make this as heat source with zone condition and also let air flow. |
July 16, 2018, 03:05 |
Tom David
Rep Power: 9 |
make each server (or a group of servers depending on what you want) a different cell zone.
The best way in my opinion would be: define a source term for each zone and use them as porous media. Specify porous terms from each server`s "system curve" (Pressure drop vs. flow rate) to control the flow rate that goes into each zone based on the pressure drop |
October 19, 2018, 11:36 |
Porous and source term
Dayananda KM
Rep Power: 8 |
Both should be applied?
about porous term , how to define zone? please explain Thank you |
October 21, 2018, 04:18 |
Tom David
Rep Power: 9 |
You should apply source term if you want to simulate the heating of the air-for this, you`ll need the thermal impedance of the server
The porous media is used to simulate the resistance of the server to the flow-the flow impedance Check this for how to define porous media: https://www.sharcnet.ca/Software/Ans...ous_media.html |
October 21, 2018, 04:30 |
Dayananda KM
Rep Power: 8 |
Thanks for reply, i understood heat source and porous media. Porous media is used to simulate flow impedance. I need a flow of 560 cfm in each server. Since it's surrounded by air zone, i cannot specify
Mass flow. How to set a particular velocity or flow rate? |
October 23, 2018, 09:34 |
Tom David
Rep Power: 9 |
First of all, If you specify the flow rate, you wont "get the airflow distribution" , it would be as you specify it. So make sure that this is actually what you want.
But I guess it really depends on what you are looking for. I would go the way I wrote two post up, that way the airflow would distribute as it would, taking into account temperature and density distributions. If you want to specify a specific flow rate, I would still do the same thing, making each rack or server a porous media, and use a pressure jump, such as a fan BC to give the momentum to the flow. you can specify such a pressure jump in a way that you will get the same flow rate for different pressures or vice versa. play with the coefficients until you do. (for example create a constant pressure jump on the entrance of a porous media that gives the flow rate you want on that specific pressure you have defined on the pressure jump BC). There is probably a another way to do it using a momentum source. But I have no experience with it, so try and read the user manual on that one |
air flow, boundary condition, data center, fluent, temperature distribution |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Graphical Animation of Fluent Simulation Data in Tecplot | Musa | FLUENT | 4 | January 19, 2012 06:44 |
2D data extracting from Fluent simulation | unknown | FLUENT | 0 | October 11, 2009 13:14 |
