Simulating thermal driven ventilation with humid air
Old   July 11, 2018, 08:08
Default Simulating thermal driven ventilation with humid air
ka1
ka1 is on a distinguished road
I am trying to simulate a thermal buoyancy driven Ventilation of a simple room through a tilted window. I was successful with using air as an ideal gas but now I want to use humid air. Do I have to use the species model in fluent? The Problem I encounterd was, that density for water vapour is const.. But it schould not be const. because the difference is the only force which drives the flow in and out of the room.
Or is there a possibility to use CFX? Because I am using opening boundarys to simulate the windstill outside area.
Thank you
ka1 is offline   Reply With Quote
Old   July 12, 2018, 02:21
`e`
`e` is on a distinguished road
If you have a function or table of values for the fluid properties, dependent on say temperature or humidity, then you could use a user-defined function to define these properties with the DEFINE_PROPERTY macro.
`e` is offline   Reply With Quote
air, humid, moist, ventilation
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
Simulating the fill of a tank of air bnicholls92 Main CFD Forum 0 January 2, 2014 06:50
questions about natural Ventilation simulation driven by thermocompression andylin FLUENT 0 March 14, 2010 08:14
VOF with air compressible and thermal effect Pei-Ying Hsieh Main CFD Forum 0 January 7, 2009 16:27
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
