July 9, 2018, 11:55 |
Local cylindrical coordinate system
Hello, I hope, someone can help me.
I have a problem setting boundary conditions in a combustion simulation. I try to simulate a combustion chamber with 8 inlets. I use velocity inlets and constant values for velocity components: Radial-Velocity: 3.67 m/s Tangential-Velocity: 3.72 m/s Axial-Velocity: 7.42 m/s I have set local cylindrical coordinate systems for each inlet, using coordinates derived from the mesh in ICEM. In the first picture you can see the local axis of one inlet. I have used a line surface using the points "Axis Origin" and "Axis Direction" from the boundary conditions of one inlet, to check the axis. It is perfectly rectangular to the inlet surface. In the second picture you can see the vectors of velocity magnitude. They are all going to the wrong direction. It seems that there is a mistake with the axis, but I cannot find it. I changed the setting for Rotation-Axis Direction in the cell zone conditions from 0-1-0 to 1-0-0 or 0-0-1, but this didnt solve the problem. If anyone knows a solution, please help me. Rotation_Axis.jpg Velocity_Vectors_Inlets.jpg |
July 9, 2018, 12:54 |
Lucky
Rep Power: 66 |
What seems wrong with your velocity vectors? They look somewhat right to me. Which direction do you want them to go at? You specify a radial and tangential velocity so of course they will point away from the local centers.
Rotation-axis is used to specify the coordinate system for the Fluent global variable Radial/Axial/Tangential velocity. You should use the axis origin and axis direction in the velocity inlet tab. But you won't be able to visualize these in Fluent using radial/axial/tangential velocity variable names because those are attached to the rotation-axis and rotation-origin in the cell zone conditions. |
July 9, 2018, 13:43 |
Thank you for your answer lucky tran.
The velocity vectors should form a swirling flow. I want to model swirl stabilized flames. So the vectors should be symmetric to the axis shown in the first picture. I have used the axis origin and axis direction in the velocity inlet tab as you recommended. |
Boundary conditions - Local cylindrical coordinate system | FluentStarter | FLUENT | 3 | February 7, 2017 06:41 |
Delete collection of local coordinate system (macro) | taillanm | STAR-CCM+ | 1 | December 12, 2016 04:46 |
Reference local coordinate system in field function | acalado | STAR-CCM+ | 2 | October 13, 2016 16:20 |
Cylindrical coordinate system - tangential velocity | alessio.nz | OpenFOAM | 2 | December 7, 2010 06:07 |
Change to local Coordinate system in Fluent | Constantine | FLUENT | 3 | November 12, 2010 02:05 |
