Initial Moment Values for QMOM
Old   July 9, 2018, 10:34
Default Initial Moment Values for QMOM
James
jayorayo is on a distinguished road
I'm running a model of a bioreactor and have been using the Discrete method for tracking the bubble sizes and numbers within the vessel. There is a wide range of sizes (and therefore bins) so I want to switch to the QMOM which should be a more efficient calculation.
I was wondering how to calculate the initial moment values that are applied to the inlet of the model? I understand that the 0th moment is the total number of bubbles per m3 and 1st moment = total length/m3, 2nd = surface area/m3 etc but how are these calculate in the first place. Based on the literature around the subject the values of these moments are based on the form of the bubble (or particle) size distribution.
I've worked through the bioreactor tutorial from Ansys and they've supplied initial values for moments 0-5 at the boundary but don't give an indication as to where these originated. Any tips or insight would be much appreciated.
Thanks!!
jayorayo is offline   Reply With Quote
Old   February 28, 2019, 05:10
Amir.11 is on a distinguished road
It's been a while but I was wondering if you still work on this issue and could help me out on definition of the initial moment values.
I've been told that the first and second moments are the mean and the variance but I don't know in this case whether the zero moment has to be normalized, or it should always be equal to the total number of particles.
So it would be great if you could share what you applied to initial moments?
Thanks
Amir
Amir.11 is offline   Reply With Quote
Old   December 31, 2019, 07:19
Lister
hfalleiro is on a distinguished road
First you need to know the amount of gas flow inlet to the system. Based on the bubble density, and expected bubble size need to calculate the number of bubbles. once you get the number of bubbles the moments can be calculated as follows
mj = N x L^j
where j is 0, 1, 2,3 ....
L is bubble size in m
N is the number of bubbles based on the inlet flowrate
hfalleiro is offline   Reply With Quote
bioreactor, fluent, population balance model, qmom
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
