Wind Turbine simulation with air (6DOF)
Old   July 8, 2018, 14:24
Default Wind Turbine simulation with air (6DOF)
Chriss
zorkwan is on a distinguished road
Hello!!
First of all, I dont have any idea about how Ansys works, I'am a beginner.
As the tittle says, is there any way to make a wind turbine rotate with the force off the wind?
I made a prototype in Solid Works and I want to see if the blades I designed works. I searched on google on how to use Ansys fluent but no luck from there, Its to complicated for me.There is only one video on Youtube that explains how to use it and make it work but its on a 2D scale,mine is 3D.
https://www.youtube.com/watch?v=8NIOC8Nl91E
Is there anyone who could help me with that?
If there is someone who could help me ,I can upload the Files that is needed
Thank You!
zorkwan is offline   Reply With Quote
Old   July 11, 2018, 01:54
Mahdi Hasan
mahdihasan is on a distinguished road
Have you done the 2D case? For 3D, I believe that you may need to use UDF. In the video, no UDF has been used and it was a simple simulation. If you have any question regarding the 2D case described in the video, I can help you with that. I am not sure about the UDF thing, but otherwise, if you have any specific question for the 3D case, you can share that. Apart from the 6DOF UDF, 2D and 3D are similar kinds.
mahdihasan is offline   Reply With Quote
Old   July 11, 2018, 05:24
GregCFD is on a distinguished road
I've only tested models quickly but I have got something to work using the inbuilt 6DOF solver for 1D rotation (ie no UDF) in 3D. I will say that one difference from the video is that you can just use the rotating/sliding mesh method inbuilt to fluent, while it introduces an interface I've found it to be generally a more robust method compared to the dynamic mesh.
GregCFD is offline   Reply With Quote
ansys, solidworks, solidworks fluent
Simulation of fan Vs wind turbine mohammad Main CFD Forum 0 November 5, 2013 09:43
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 18:52
3D simulation of wind turbine in Yaw wind(in a lateral wind) mohammad Main CFD Forum 0 December 28, 2010 04:26
wind turbine simulation problem dennis0131 Main CFD Forum 4 November 22, 2010 05:26
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 03:12
