Inlet Boundary Condition
Old   July 6, 2018, 14:39
Default Inlet Boundary Condition
farhad
farhad-j is on a distinguished road
Hello friends.
I'm modeling a shell and tube heat exchanger in Fluent.
It contains 27 tubes. All tube inlets are organized in one component as "tube inlet" with 0.02 kg/s mass flow rate.
Will this mass flow rate be automatically divided between tubes by fluent (like .02/27 kg/s) or I have to divide it?
Thanks for reply.
farhad-j is offline   Reply With Quote
Old   July 6, 2018, 21:01
`e`
`e` is on a distinguished road
If the tube inlets are all one boundary zone then I would expect that they would share the mass flow rate of 0.02 kg/s, whereas having 27 individual inlet zones would have a total mass flow rate of 27*0.02 kg/s. Regardless, you should double check with Postprocessing > Reports > Surface Integrals to ensure that the inlet condition is what you intended.
`e` is offline   Reply With Quote
Old   July 6, 2018, 21:16
farhad
thanks. it was helpful
#boundary;#inlet
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
