Vorticity/ velocity curl in STN frame
Old   June 26, 2018, 07:38
Thumbs up Vorticity/ velocity curl in STN frame
Ethan Walker
EthanWalker is on a distinguished road
apologies if this has been answered previously but I could not find a result on a search.
I was wondering could someone explain how to calculate velocity curl in the STN frame in CFD post in fluent version 17.1
I'm modelling a turbine and when i make a contour of curl using the standard velocity curl under vortex core i get discontinuities between the stationary and rotating domain that I believe would be solved if it was the STN frame.
has anyone a solution to this?
Thanks
EthanWalker is offline   Reply With Quote
Old   December 3, 2018, 17:07
Default Interface issues
Liam Parker
LParker is on a distinguished road
Hi Ethan,
I also had these issues with a project if mine recently. My simulations were on a diffuser augmented wind turbine. No matter what i tried the vortices were irregular and discontinuous at the interface. Instead of the rotating domain only encasing the blades, i made the rotating domain larger and extended it in to the wake of the turbine (around 2 diameters). Doing this didn't change the other properties such as torque produced by the turbine ect, but i was able to visualise the vortices in the wake of the turbine properly. Just make sure you set any surfaces that aren't rotating but are in the rotating domain to counter rotating walls.
LParker is offline   Reply With Quote
cfd post, fluent, vorticity
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Having problems getting the mean vorticity field from mean velocity field Martin1 Fluent UDF and Scheme Programming 1 June 18, 2015 09:20
vorticity velocity method dadashi_ali Main CFD Forum 2 October 9, 2003 11:48
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
