How to simulate the LOX/GH2 spray combustion
Old   June 25, 2018, 12:17
Default How to simulate the LOX/GH2 spray combustion
kanmaniraja is on a distinguished road
Recently, I am trying to simulate a spray combustion using gaseous methane and liquid oxygen for the liquid rocket engine (Non-Premixed Model--> equilibrium approach).
To validate the numerical procedure (Non-Premixed Model--> pdf of Equilibrium approach), I have taken the Rocket Combustion Modeling (RCM-2 case)_10 bar as a chamber pressure in which the gaseous hydrogen and liquid oxygen as propellant. To simulate this, I have used the mass flow inlet boundary condition for gaseous hydrogen and discrete phase model (Lagrangian approach) for liquid oxygen as droplets so that it will evaporate. I have created the PDF table using chemical equilibrium from the Non-Premixed combustion model in which the boundary as (h2 = 1 (fuel), 0 (oxid)) and ((o2 =0 (fuel), 1 (oxid)). And I have given 1 for mean mixture fraction at the hydrogen mass flow rate boundary condition. it shows that the combustion does not happen.
When I created the same PDF table by using chemical equilibrium from the Non-Premixed combustion model in which the boundary as (h2 = "0" (fuel), "1" (oxid)) and ((o2 ="1" (fuel), "0" (oxid)). and I have given "0" for mean mixture fraction at the hydrogen mass flow rate boundary condition. I checked that the combustion has happened and I plotted the temperature along axial and radial at a different location as with the experimental data, which showed that the simulation result is agreed with the experiment. I want to know this way of approach is correct or wrong?.
Please kindly request you to give your suggestion or anything about this.
Thank you very much.
kanmaniraja is offline   Reply With Quote
discrete phase model, gh2, lox, spray combustion
Two-Phase Flow in Spray Combustion Vajira Main CFD Forum 4 November 4, 2017 14:31
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 07:20
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 07:09
Multifuel Diesel Spray and Combustion usker Siemens 12 December 1, 2007 20:08
Spray combustion modelling including particle seperation Vajira Main CFD Forum 0 November 21, 1999 13:46
