Heat source at pressure outlet?
Old   June 25, 2018, 07:55
Default Heat source at pressure outlet?
adrien
didimoray13 is on a distinguished road
Hi everyone,
I have a coupled wall that need to be split into two separate faces: one pressure outlet and one wall (the reason for is that it is the junction of two separate regions).However, I need the heat transfer between the two faces:
  • Temperature from the outlet applied to the wall (easy with UDF profile)
  • Heat flux from wall to pressure outlet
I'm sadly not aware of any means to impose a heat flux to an outlet. Do you have any idea (maybe using heat source terms?)?
Thanks!
didimoray13 is offline   Reply With Quote
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
