June 20, 2018, 05:38 |
Modelling air cooling of an engine
Tommaso Sab́a
Hi all,
I'm facing a few difficulties in modeling the convective heat transfer between an air-cooled engine and the airflow over it. Basically I want to run a few steady-state simulations in order to validate the best configuration among the few that I've set up and see which one keeps the engine at the lowest temperature. I tried a few solutions to model the convection but found no solutions that made sense - I'd expect the air to heat up while it goes down the engine and therefore to have a temperature gradient along the engine. Instead, the engine maintains basically the same temperature over its entire surface and the air has a temperature gradient only in the Y-axis and not in the X-axis. I have defined two cell zones, fluid (air) and solid (engine). Created an interface (surface of the engine), set it to wall and then selecting Coupled in the Thermal sub-menu. Activated energy equation. Initialized the case and then patched the solid zone to 400 K. Results show the engine surface ranging 298-300 K which I think makes no sense. What am I missing and what should I do to properly model my case? Thanks to who wants to help me a bit. |
June 27, 2018, 15:13 |
Tommaso Sab́a
Up
Anyone wanting to help? |
Modelling room ventilation air flow | todda7 | Main CFD Forum | 0 | April 12, 2017 14:51 |
[DesignModeler] Environmental Air Modelling | oozcan | ANSYS Meshing & Geometry | 2 | August 14, 2016 18:52 |
Modelling Heated Air inside a Cylinder | krokodilcho | FLUENT | 0 | June 24, 2016 09:15 |
CFD code for IC engine modelling | lost.identity | Main CFD Forum | 5 | November 2, 2011 12:08 |
Regenerative cooling rocket engine | Brian | Main CFD Forum | 0 | November 12, 2003 06:59 |
