No convergence when PRESTO scheme is employ in water turbine modeling |
June 19, 2018, 12:38 |
Abdulaziz Abutunis
Rep Power: 12 |
Hello All:
I am simulating a water turbine with structured mesh for all domains. I noticed that when PRESTO scheme is employed the solution will not converge especially the momentum where its residual goes to very high values. My second concern is that, when using single reference frame, the torque I got is higher than the experimental one: at some rotational speed it is twice and higher rotational speed it may reach one order of magnitude. Thanks Aziz Last edited by ama294; June 19, 2018 at 12:42. Reason: Missed some clarification |
no convergence, presto |
Convergence order of three point central finite difference scheme | lmalenica | Main CFD Forum | 20 | November 11, 2017 03:26 |
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 21:20 |
Order of accuracy in a combined scheme | kaush | Main CFD Forum | 5 | July 21, 2017 05:47 |
Problem with convergence using 2nd order scheme for multiple elements car wing | Trytytka | FLUENT | 0 | December 31, 2016 09:42 |
Convergence in MARS scheme | shiv | Siemens | 10 | January 31, 2008 21:27 |
