How to define thermal property "Expansion" in Fluent
Old   June 18, 2018, 06:46
Default How to define thermal property "Expansion" in Fluent
Swaroop
raghuramswaroop is on a distinguished road
Where should I define the thermal property "Expansion (alpha)" property during defining a material ? I can't see the option.
raghuramswaroop is offline   Reply With Quote
Old   June 18, 2018, 10:38
Lucky
It depends on what equation of state you are using.
What are you trying to model that needs the thermal expansion coefficient? In many cases, the thermal expansion is implicitly defined by the eos for density. A constant density eos for example, has an alpha of 0.
local thermal non equilibrium model in porous media adi.ptb Fluent UDF and Scheme Programming 0 November 1, 2014 16:00
How to define parameters for multi periodic boundary conditions in Fluent uuusheng FLUENT 1 October 14, 2014 07:48
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 09:39
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
DEfine NON NEWTONIAN Blood flow in FLUENT jusepina Main CFD Forum 0 January 18, 2009 17:43
