Non-newtonian fluid viscosity-HB model
Old   June 15, 2018, 18:14
Default Non-newtonian fluid viscosity-HB model
ywan168 is on a distinguished road
I am writing here to ask someone if he or she ever faced this kind of problem, When I simulate a fluid displaces another fluid, actually a fluid with constant viscosity displaces another non-newtonain fluid. When I set both fluids having constant viscosity, the solver can work but didn't calculate the right velocity. When I set the second phase as non-newtonain model (HB model), the solver didn't run, giving floating point exception error. (I use VOF, energy, and realizable k-e, enhanced wall Fn)
Anyone can explain this?
ywan168 is offline   Reply With Quote
Old   June 16, 2018, 15:14
RaiderDoctor is on a distinguished road
I don't think we have enough info to begin troubleshooting this problem. Could you include an image of your setup and mesh.
A floating point excetpion could mean a variety of things. When you look at your residuals, are they diverging?
RaiderDoctor is offline   Reply With Quote
Old   June 21, 2018, 16:48
Hi, it's not diverging now when I change my outlet condition to mass flow out. Now it's computing but the velocity flowing up from bottom is not calculated right.
Old   June 22, 2018, 11:27
I'm sorry, but I don't have enough info on your problem to really understand what's going on. Again, could you post a picture of your mesh, and tell me a little about your setup?
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
How to use the CFX periodic interface zhihuawan CFX 61 January 15, 2018 17:20
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
