Enclosure not compact enough in Ansys Fluent. Can the enclosure touch the o |
June 13, 2018, 11:37 |
-- Country other than USA or Canada --
I am using Ansys Fluent to simulate a heat fin setup. The enclosure around the heat fins has one wall as inlet and another as outlet. The remaining four walls must touch the fin setup so that incoming air is forced to pass through the fins and not around them. However bringing the enclosure too close is apparently not allowed. The exact message displayed on doing so is :
An error occurred while creating enclosure. Try increasing cushion value. I am calculating pressure difference between the inlet and the outlet as a result of the fin setup. The values are much higher than theoretically calculated and I suspect it is because currently there is still some gap between the fins and the surrounding walls. Is there any way around this problem? Thanks. |
June 13, 2018, 14:19 |
Rep Power: 10 |
Hi, welcome to the forum. Could you post a few images of your setup so that we have a better understanding of what you are attempting to do?
ansys, fluent, heat and mass transfer |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 03:48 |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 11:29 |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 11:23 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 13:07 |
ANSYS and ANSYS Fluent | Field85 | ANSYS | 3 | May 17, 2015 17:21 |
