number for the paricles number are not displayed in cfdpost
Old   June 8, 2018, 01:16
Default number for the paricles number are not displayed in cfdpost
Shoonya is on a distinguished road
Hello All:
I am facing a problem while displaying the number of particles in CFD -Post. When I load the data in CFD-Post, it shows the following error:
"ERROR
Unable to convert units from 'm^-3' to 'm^-3 s^-1'. No valid conversion found."
In fluent results>coutour section, it properly displays the number of particles, whereas in CFD-POST, the same data file does not display the numbers of particles and the error mentioned above appears. The data does not corresponds to 'm^-3', why does CFD-Post tries to convert it into 'm^-3 s^-1' units and then fails in doing so.
I have added the screenshot of the error.
Please help
Thanks and regards
Dinesh
Shoonya is offline   Reply With Quote
cfdpost, number of particles, unit conversion
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
