problem numerical results of lift and drag in airfoil simulation using fluent solver |
Mohammmad ali gheidi shahran
Rep Power: 9 ![]() |
hello everyone,
i have a problem in validation the test results( numerical and experimantal) when i using fluent solver in 2d NACA 4412 airfoil simulation. in zero AOA error of CL is 7.5% and CD is 12%. i want to reduce errors but i can't. i am using the structured meshing using ICEM. turbulence modeling i am using are SA & K-OMEGA(SST). when i trying to refine the mesh to reduce error and close to experimental datas @ 3e+6 reynolds number error results are more than above( 7.5 and 12%) i dont know how to overcome this problem please help me.... thank you ![]() ![]() ![]() |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Ahmed body simulation gives unexpected results in su2 6.0 | anas651 | SU2 | 0 | March 28, 2018 03:42 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
