June 6, 2018, 10:08 |
FSI 2D - dynamic mesh
Marcin
Rep Power: 10 |
I am preparing 2D FSI analysis in ANSYS Fluent and Mechanical. For this purpose, I created extruded (sweep) mesh for the one layer. I am using smoothing and 2.5D remeshing. Unfortunately, I had the NCV (Negative Cell Volume) problem. My case is some flap in the water stream. In the below picture, I showed the cell volume contour and mesh; it shows only negative cell volumes. Please give me some advices, what could be wrong. I tested many time step sizes, the min and max cell size in dyn mesh settings is OK. Regards Destroy |
June 6, 2018, 17:10 |
Marcin
Rep Power: 10 |
It seems to me like the information about the flap deformation is not transferred from Mechanical to Fluent.
The mesh before calculation: and after calculation, with negative cell volumes: It's strange - I set appropriate data transfers and dynamic mesh zones. But I'm not sure if I should search the mistake here - maybe it's only dynamic mesh issue? |
Dynamic Mesh | kennyboy | FLUENT | 1 | February 23, 2019 01:52 |
Dynamic Mesh Settings for compressed FSI | ANSYS_Man | FLUENT | 0 | July 26, 2016 11:11 |
FSI Dynamic Mesh Separating? | dcp2387 | FLUENT | 0 | June 20, 2016 17:50 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
