Get high skewness after setting mesh interface in Fluent |
May 31, 2018, 05:28 |
Zhongqi Zuo
Rep Power: 8 |
hello,
I have a problem: I used a pair of interfaces to connect 2 parts of mesh, and the quality of mesh is greater than 0.39 in Fluent. Before I set up the interface, everything seems fine. And after the set up, when I run "Check Case", the result becomes "Maximum cell skewness is greater than 0.98". And the case become divergent after a few steps (turbulence ration is greater than 1e5). Is this error caused by the interface? The mesh interface dialog is shown below. Thank you in advance! Last edited by MrZZQi; May 31, 2018 at 05:32. Reason: add figure |
May 31, 2018, 07:17 |
checked mesh in ICEM
Zhongqi Zuo
Rep Power: 8 |
And I checked the mesh in ICEM, the Equiangle Skewness is greater than 0.35 (perhaps means the skewness is supposed to be less than 0.65 in Fluent?)
fluent, high skewness, interface |
mesh interface in Fluent | AvaShahrokhi | FLUENT | 10 | December 25, 2020 08:58 |
High skewness on importing Pointwise mesh in Fluent | Shubham_SD | Pointwise & Gridgen | 0 | February 7, 2017 10:56 |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 07:08 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
