Problems in generating mesh
Old   May 29, 2018, 18:27
Default Problems in generating mesh
Joćo Vitor de Melo Rodrigues
Joćo VMR is on a distinguished road
I'm having a problem during mesh generation. After I edit the geometry that I analyzing (wind turbine simplifies), when I generate the mesh to start my analysis are appearing some errors. Anybody help me?
Three types of errors are appearing:
1- One or more entities failed in the mesh. The mesh of bodies containing these entities may not be up to date. However, meshing can be successful on other entities.
2- One or more surfaces can not be meshed with acceptable quality. Try using a different element size or virtual topology.
3- A mesh can not be generated using the current mesh options and settings.
Joćo VMR is offline   Reply With Quote
fluent, mesh, wind turbine
[Salome] Problems for creating mesh in salome to OPENFOAM bye bye my blue OpenFOAM Meshing & Mesh Conversion 8 December 5, 2023 01:57
[ANSYS Meshing] First layter thickness on mesh causing problems Rik102 ANSYS Meshing & Geometry 0 November 4, 2016 10:51
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 18:36
[blockMesh] mesh causing problems with convergence Tetragramm OpenFOAM Meshing & Mesh Conversion 0 September 22, 2012 17:00
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
