Error with DPM particle file input
Old   May 24, 2018, 01:17
Default Error with DPM particle file input
Nathan Krumland
nkrum is on a distinguished road
I have written a custom injection file in MATLAB to input into my Fluent model. When I ask to list the particles from the injection is throws me a few error messages saying so many particles were "lost outside the domain in radial staggering; reducing staggering factor to XX%".
Then when I look at the locations of the particles Fluent will use in the model, they are completely different than the ones I wrote in the injection file.
Any idea on how to get Fluent to like my injection?
nkrum is offline   Reply With Quote
Old   June 29, 2018, 15:43
Julia Hartig
juliahartig is on a distinguished road
Hey nkrum,
I had a similar problem when using the volume injection beta feature in Fluent, so I'm switching to file injection. Did you figure this out? If not, I might find a solution/explanation once I finish coding the file injection in my simulation, if you want to send me your injection file I could check it out.
juliahartig is offline   Reply With Quote
Old   June 29, 2018, 16:12
Nathan Krumland
Hi juliahartig,
I found a work-around to the problem. I think what fixed it was initializing the model first with a surface injection based off a surface of the model already present, then inserting the injection file.
dpm fluent, error message, file injection, staggering
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
