How to simulate this negative pressure condition on Fluent?
Old   May 22, 2018, 04:48
Lightbulb How to simulate this negative pressure condition on Fluent?
Grey is on a distinguished road
I want to simulate a model which has a negative pressure/suction at the common outlet and openings just like the one shown in the picture below. I want the wind to pass through the model, and the common outlet to have negative pressure(which means the system has to suck wind in). I made couple of trials by using fill command. But so far nothing worked yet. The First model without applying the negative pressure at the outlet performed successfully as I created an extruded part body as wind domain on the model surface on Design Modeler, and converted this part body and the surface body(the model which was imported from Rhino) into one part body by using Form New Part. But the obtained solution of the below model was incorrect. Refer the attachments for understanding which includes Rough representation of current model and Results from the first model. Kindly suggest me a best practice for this condition of my simulation.
https://drive.google.com/file/d/1Xhmnjgx0uew-Ob8jMRQCpLSKoq_haNr7/view?usp=sharing[/IMG]
https://drive.google.com/file/d/1tyGCYLtTIj7Wqtyn4wJdBbtiyAdQtI5q/view?usp=sharing[/IMG]
Grey is offline   Reply With Quote
fluent . cfx, hvac
Fluent Pressure Outlet Boundary Condition kauf0162 FLUENT 2 October 21, 2014 12:09
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Is Fluent applicable to simulate velocity distribution under low pressure (~100pa)? beastieboys FLUENT 0 March 3, 2010 02:55
Different kinds of pressure in FLUENT Mattia FLUENT 0 October 22, 2007 09:52
