May 12, 2018, 19:08 |
How to get Thrust from a propeller?
Rep Power: 10 |
I am doing a cfd simulation of a propeller, I would like to know how to get the thrust force using Fluent? I know it gives the forces components, so I created a force monitor using the vector (-1,0,0) given my flow direction is in the X direction, but it seems like I am having figures, as they show in negative and too big. Thank you |
May 13, 2018, 00:38 |
teguh hady
Rep Power: 18 |
You should give the more details of your simulation. I think it can be you choose wrong axis so the value get negative. You shoud check the velocity vector near the blades. To know whether the rotation is correct.
Now Or Never!!! |
May 13, 2018, 04:22 |
Rep Power: 10 |
Thanks for the reply, my propeller is turning in the counter clock wise direction ,as it is designed to do , with the rotation axis being the x axis and the flow direction is the x axis as well, which makes the thrust in the opposite side.
ducted fan, fan, fluent, thrust |
calculating thrust of a propeller | amin.z | FLUENT | 5 | September 15, 2023 12:51 |
Calculation of thrust and torque for propeller | aeksberde | OpenFOAM Post-Processing | 2 | October 28, 2019 05:23 |
Propeller Thrust Method | Aidan.B | CFX | 3 | October 21, 2015 18:40 |
Propeller thrust analysis | euclid | ANSYS | 0 | June 24, 2015 09:39 |
Propeller thrust at diff. advance ratio (CFX 5.7) | Zoltan | CFX | 9 | April 27, 2005 08:23 |
