Pressure Coefficient to large when simulating on building
Old   May 11, 2018, 05:43
Thumbs down Pressure Coefficient to large when simulating on building
Ivan Nikolaisson
ivan.nikolaisson is on a distinguished road
Hello
Im trying to simulate wind pressure on a building, and i want to obtain the pressure coefficient that is acting on the building. I have made my reference values correspond to my inlet, however, my pressure coefficient has the range from -3 to 2. In reality it should be between -1 and 1.
Any tips on where I could have gone wrong?
This is the contour plot of the building:
ivan.nikolaisson is offline   Reply With Quote
Old   February 28, 2019, 12:37
Antoine
antoine_hub is on a distinguished road
Hi Ivan,
I am suspecting the static free stream pressure you use to calculate the coefficient pressure is not correct.
Best regards,
Antoine
antoine_hub is offline   Reply With Quote
Old   April 4, 2019, 02:04
Michael Fily
bietchetlien1995 is on a distinguished road
I’m doing the same topic like you. To compare with the wind tunnel test. Btw. I hope to have the group to discuss more ab this fields. I’m jumping into as a newbie
bietchetlien1995 is offline   Reply With Quote
pressure coefficients
Pressure coefficient Tensian OpenFOAM Post-Processing 21 December 17, 2019 10:29
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
the pressure coefficient vs angle in CFX?? Jwolf CFX 1 December 14, 2012 08:31
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
