May 8, 2018, 10:09 |
frictional pressure loss in pipe
Payam
Rep Power: 9 |
hi
i want to simulate flow between annulus. The BCs are velocity inlet, pressure outlet and walls. fluent solve the flow correctly but i dont know how to calculate frictional pressure loss [Pa/m] in fluent. should I use custom function ? or fluent can calculate it? |
May 9, 2018, 21:19 |
Lucky
Rep Power: 66 |
This is a postprocessing endeavor. DP is really nice and well defined in 1D, but in 3D not so straightforward & you have to replace it with an equivalent 3D definition (i.e. difference in average pressure between outlet and inlet). You can get these averages from Fluent and then the remaining calculation can be done by hand.
3dflow, annulus, flow |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
total pressure change in a pipe flow | Im | FLUENT | 5 | February 23, 2017 09:55 |
Pressure gradient through vertical pipe | 0906536m | FLUENT | 0 | November 18, 2013 18:07 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 07:52 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
