Calculate Nusselt number
Old   May 3, 2018, 20:37
Default Calculate Nusselt number
Joe
enayath is on a distinguished road
Hello everyone,
I would like to calculate the Nusselt and heat transfer coefficient in my domain. I use "Reports" and then "area-weighted average", wall fluxes and surface Nusselt number on the walls that I would like to investigate.
The question is about the reference value for Temperature. As I change this value, I get different NU or h values. what is the right way to choose the reference value? I used Boussinesq and the applied BCs are a constant temperature value of 310 and 320 K.
I read the FLUENT tutorial and was expecting that NU is calculate based on the wall temperature and the temp near the wall. If that's the case, the reference temperature should not change the results.
What am I missing?!
Thank you in advance!
enayath is offline   Reply With Quote
Old   May 4, 2018, 01:47
Lucky
Before Nusselt number you need the heat transfer coefficient. The reference temperature is needed to calculate the heat transfer coefficient in Newton's law of cooling.
Usually there is some common sense value to set the reference temperature to (the temperature that drives the heat transfer). Otherwise, you need to find some convention for your problem. If a convention does not exist, then you get to make it up.
From a theoretical point of view, the pair of heat transfer coefficient and reference temperature are defined together. I.e. it makes no sense to speak of a heat transfer coefficient unless you have also defined the reference temperature. There is no meaning to one without the other.
Old   May 4, 2018, 14:18
Joe
Thank you for your reply.
How the heat transfer coefficient is being calculated?
Old   May 4, 2018, 16:40
Lucky
Heat transfer coefficient is again calculated using Newton's law of cooling and the wall heat flux. This heat flux is what is calculated using the wall temperature and temperature near the wall, and it is this heat flux that does not depend on the reference temperature.
calculate Nusselt number dewey OpenFOAM Running, Solving & CFD 7 April 24, 2019 11:16
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 05:49
How to calculate Nusselt number SeRGeiSarov Main CFD Forum 4 May 6, 2009 02:57
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
