May 3, 2018, 15:11 |
Natural convection solver
André
Rep Power: 10 |
Hi gents,
so I'm trying to run a simulation where I have a transient fire inside a tunnel section. I am using energy and mass sources to model the fire, and zero pressure BC at the outlets. The fire is supposed to take a few minutes to ramp up so this is a quite large simulation (both due to the size of mesh and physical time span) I am using pressure-based solver with SIMPLE, tried using 1st order schemes and under-relaxations down to 0.5 but still am having trouble converging. I tried using adaptive time steps but still no luck. Should I just use a very small time step (i.e. 1e-4 ?)in the beginning, and then increase this? Thanks for your help!
Sapere aude! |
Heat transfer between two closed cavities with natural convection | Czarulla | FLUENT | 2 | August 5, 2020 13:36 |
UDF of natural convection in 3D cylinder | a_Sarlak | Fluent UDF and Scheme Programming | 0 | November 7, 2015 09:19 |
the incompressible idea gas law in natural convection | hotboy | FLUENT | 1 | June 22, 2015 22:02 |
Natural Convection around two spheres in a box - chtMultiRegioSimpleFoam | salvo-K61IC | OpenFOAM | 4 | January 16, 2015 14:27 |
Natural convection in oil filled enclosure | abu250feldman | FloEFD, FloWorks & FloTHERM | 5 | December 4, 2013 10:37 |
