Simulation of a groove bearing
Old   May 3, 2018, 06:40
Default Simulation of a groove bearing
Aja
aja1345 is on a distinguished road
I am simulating a spherical groove bearing….e.g. A bearing that has spiral grooves on the ball…(Please see the following figure)...One of the most interesting features of a spherical spiral-groove hearing is that it is capable of taking up a radial load as well as an axial load.
There is a kind of lubricant between ball and cup, so as to prevent metal-to-metal contact (Full film lubrication theory). The dimension of groove and gap between ball and cup are in (mm) and (micron).
Also, please see this reference.
This bearing has two pump effect and leakage effect inside the grooves. For the ideal bearing, It should be: pump effect=leakage effect >>> (so as to prevent metal-to-metal contact). The model is as follows (the model and mesh are created in Gambit):
This bearing has displacement in X-direction, Y-direction, and Z-direction (this simulation needs using UDF). But firstly, I am simulating this problem without the displacement (this simulation doesn’t need using UDF). I simulated this problem (without displacement) by using the following setup:
Solver: type: pressure based and Velocity formulation: Absolute
Time: steady
Model: Standard K-e, scalable wall Function
Fluid: I changed density and viscosity based on a lubricant that there is between the ball and cup. Fluid is incompressible.
Cell zone condition: Frame motion> apply Rotational velocity
Ball: Moving wall > Rotational> relative to adjacent cell zone> apply 0 rad/s
Cup: Moving wall > Rotational> absolute > apply 0 rad/s
Inlet and outlet: inlet pressure and outlet pressure…Is this right? Is it possible to use other boundary conditions on inlet and outle?
Pressure-velocity coupling: scheme: simple
I have not any information about UDF. I am grateful that guide me in this simulation and give me useful files in these cases (UDF and simulation).
Thanks.
aja1345 is offline   Reply With Quote
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 21, 2017 00:47
Control simulation to apply different fields with chtMultiRegionFoam jmdf OpenFOAM Running, Solving & CFD 0 February 29, 2016 08:05
restarting paused transient simulation using reactingFoam JMDag2004 OpenFOAM Running, Solving & CFD 1 August 10, 2015 11:15
Periodic boundary conditions for moving reference frame (MRF) simulation) guebelib STAR-CCM+ 1 April 15, 2015 07:55
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 13:27
