April 26, 2018, 21:22 |
Density or Pressure based solver
Ashwin
Rep Power: 9 |
I'm trying to do a liquid heating problem. I have liquid density change, specific heat change and viscosity change as a function of temperature. I'm confused if I should use Pressure based solver or Density based solver for the liquid heating problem. I tried using Pressure based solver, but at a certain point in my simulation I get floating point error. This is not due to time stepping problem. Could someone tell me what solver I should use? |
April 27, 2018, 05:34 |
Lucky
Rep Power: 66 |
Both should work out of the box. The pressure based solver is probably the better choice though since your case is incompressible.
You probably just need to tinker with your setup to figure out why it's diverging. |
fluent |
How is the accuracy using VOF (pressure based solver) on supersonic flow | air_fun | Fluent Multiphase | 1 | August 25, 2021 01:59 |
Boundary face values in density based solver? | Chen Zhi | FLUENT | 3 | November 28, 2019 07:51 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Using Density Gradient C_R_G(c,t), Pressure Based Solver | Anirudh_Deodhar | Fluent UDF and Scheme Programming | 1 | October 25, 2013 06:43 |
