One of the inlets can not flow out in the case used by LES
Old   April 26, 2018, 11:11
Talking One of the inlets can not flow out in the case used by LES
Jingwei
Jingwei36 is on a distinguished road
I'm modeling a tube flow with two inlets and two outlets. I use the Large eddy simulation, and initialize with 'all zone'. Then, only inlet 1 can flow out while inlet 2 can not flow out. I was so puzzled. Thank you for your reply.
Jingwei36 is offline   Reply With Quote
Old   April 26, 2018, 12:15
Lucky
You should learn how to initialize properly and not using the "compute from" feature. The compute from feature is a convenience option. When you choose compute from, the values that will eventually be used set as the initial values will appear in the GUI immediately. What you see is what you get. If you're unhappy with it, then change it!
If you are doing LES, it's better to start with a steady or RANS simulation to provide the initial conditions.
Old   April 27, 2018, 10:43
Thumbs up
Jingwei
It is very nice of you to answer this question. With your advice, the simulation is worked correctly. Thank you very much. And I am still wondering that why two inlets can flow out with other viscous model when compute from 'all zone', while only inlet 1 can flow out with LES.
fluent 12.1, initialize, inlet, les
Oscillating flow over a cavity validation case Sparow89 FLUENT 0 June 2, 2016 16:18
Numerical error or case error? Flow in a 3D pipe fsalvucci OpenFOAM 40 January 30, 2013 08:10
Different Flow in One Case Dong Fu FLUENT 0 February 1, 2008 10:28
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 17:40
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
