Positive radiative heat flux, negative convective heat flux how can this be ? |
Henry
Rep Power: 8 ![]() |
I have attached pictures of the problem. Basically it is burners heating up a kettle. THe first shows the fluid domin and the second the kettle.
Why do I get radiative heat flux back into the fluid domain? Is this possible or is the model not accurate? best regards. I though that q rad = emissivity constant x (T-Tinf) and q convective = h x (T-Tinf) so how can one be positive and the other not ?? regards |
convection, fluent, radiation |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
