Negative cell volume detected
Old   April 24, 2018, 12:51
Default Negative cell volume detected
sagi shahar
sagi shahar is on a distinguished road
Hello everyone,
I am trying to create a fluent simulation for free falling of flat plate in-water. The plate falls between a guide box walls that are located very close to it (gap of 0.5-2 mm) and allows the plate to move only on the vertical direction.
The problem occurs when I run the simulation.
It stops at the beginning and shows me the massage: "Negative cell volume detected".
Attached a document with print screens of the settings that I set for the simulation. The pictures are pretty unclear because I had to compress the file, so if you don't understand it I would like to send you the original file.
I will be happy if someone here will be able to help me, because I've tried to solve it in many ways and I didn't succeed yet.
Thank you,
Sagi
sagi shahar is offline   Reply With Quote
Old   May 24, 2018, 13:14
maccheese is on a distinguished road
Did you try "display zone motion" and "preview mesh motion" in the dynamic mesh settings? With these functions you can get a good overview on which time step size is required for the remeshing to work properly.
I have faced the same problem and in my case I had to choose a smaller time step so the mesh doesn´t fold.
maccheese is offline   Reply With Quote
Old   May 29, 2018, 02:06
Thumbs up
Blue's Avatar
Blue is on a distinguished road
Originally Posted by sagi shahar View Post
Hello everyone,
Thank you,
Sagi
Use tetrahedral mesh and small time-step. See the previous discussion on this website.
Blue is offline   Reply With Quote
Update-Dynamic-Mesh failed. Negative cell volume detected Hellema FLUENT 0 April 19, 2018 12:00
Negative volume cell detected Hooman.Fa Fluent Multiphase 0 February 12, 2018 10:15
negative cell volume detected (dynamic mesh analysis) g-wagon FLUENT 15 September 2, 2017 23:03
Sliding mesh with negative cell volume detected Moen FLUENT 0 August 3, 2016 00:59
user defined function cfduser CFX 0 April 29, 2006 11:58
