What's the TUI command for turning on the Vortex Method in Boundary Conditions: LES? |
April 23, 2018, 04:08 |
Rep Power: 18 |
Dear all,
I cannot find the TUI command for turning on the Vortex Method for the inlet boundary condition and setting the number for an LES simulation. Can it be done? Any help would be much appreciated. Cheers, |
April 23, 2018, 07:05 |
Bond Chris
Rep Power: 9 |
It's available in /define/boundary-conditions/set/ <choose your boundary condition here>/ les-spec-name/ no yes After this in .../les-spec-name/vm-number-of-vortices |
April 23, 2018, 07:33 |
#3 | |
Rep Power: 18 |
I was pre-suposing that the k-w SAS model would have the same TUI commands available as LES as the Vortex Method appears in the GUI but it doesn't seem to recognise les-spec-name. Any thoughts? Sorry I should have been more specific |
April 23, 2018, 07:50 |
Bond Chris
Rep Power: 9 |
Are you using a mass flow inlet boundary condition? The fluctuation method can only be defined for velocity inlet or pressure inlet boundaries. I am able to find the les-spec-name command, with the k-w SAS model, for velocity and pressure inlets |
April 23, 2018, 14:37 |
Rep Power: 18 |
Strange. I'm using a velocity inlet and also the kW sst sas model. Could you paste the exact commands you wrote please?
April 23, 2018, 15:36 |
#6 | |
Bond Chris
Rep Power: 9 |
define boundary-conditions set velocity-inlet inlet () les-spec-name no yes vm-number-of-vertices 200 quit in the above command "inlet" is the name of my velocity-inlet boundary condition, and 200 is an arbitrary number of vortices. |
April 23, 2018, 16:32 |
#7 | |
Rep Power: 18 |
Looks like to input the number of perturbations is then through: /define/boundary-conditions> v (inlet) zone id/name [inlet] Velocity Specification Method: Magnitude and Direction [no] Velocity Specification Method: Components [yes] Reference Frame: Absolute [yes] Use Profile for Supersonic/Initial Gauge Pressure? [no] Supersonic/Initial Gauge Pressure (pascal) [0] Coordinate System: Cartesian (X, Y, Z) [yes] Use Profile for X-Velocity? [yes] Use UDF Profile for X-Velocity? [yes] Use Profile for Y-Velocity? [yes] Use UDF Profile for Y-Velocity? [yes] Use Profile for Z-Velocity? [yes] Use UDF Profile for Z-Velocity? [yes] Fluctuating Velocity Algorithm: No Perturbations [no] Fluctuating Velocity Algorithm: Vortex Method [yes] Number of Vortices [190] |
June 1, 2018, 19:05 |
#8 | |
Rep Power: 18 |
fluent, les |
Implementing vortex method for generating inlet conditions in LES | cfdonline2mohsen | OpenFOAM Pre-Processing | 4 | September 18, 2022 13:48 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
