April 22, 2018, 20:43 |
Post-processing Particle History
Svetlana Tkachenko
Rep Power: 15 |
I would like to obtain the value of shear stress acting on the particles from the tangential velocity component (10.1002/ceat.201500378 Equation 1). Evaluating this variable requires the knowledge of spatial derivatives such as the derivative of the tangential particle velocity (where the particles are revolving around an axis) by the radial distance of the particle location.
As far as I know Fluent provides particle history data which contain the particle coordinates (X Y Z) and the particle velocity components (U V W). If this data could be exported to MATLAB I would be able to write the derivative code myself however I only found an option to export the data to geometry or ensign or fieldview format, of which CFD-Post reads in one of these formats and provides particle track - but this does not work well as the particle track variables are then not listed in the list of variables for defining a custom expression or variable. Please suggest what is the best way to approach this problem. |
particle data, tracking |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 07:21 |
CFD -post particle variable | sjtusyc | CFX | 0 | September 14, 2012 23:09 |
[OpenFOAM] is parallel processing available in parafoam for post processing? | sachinlb | ParaView | 1 | August 14, 2012 10:52 |
post processing particle motion | phsieh2005 | Main CFD Forum | 0 | December 16, 2009 12:48 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 21:51 |
