Update-Dynamic-Mesh failed. Negative cell volume detected |
Hellema
Rep Power: 0 ![]() |
I model a blower, a fan in a casing for a transient simulation. For this I create a blade zone: I make a boolean air - blades and then do SMM (sliding mesh method) on this impeller zone. The simulation fails with "Update-Dynamic-Mesh failed. Negative cell volume detected.” I would suspect the booleans declared in the Geometry but they look well defined. I tried to simplify my model (no holes no screws). I also tried to adapt my mesh by dividing it with Multizone with hexa dominant. But it's not sufficient to reduce the skewness.
Do you have any suggestions? Thank you in advance. |
fluent, meshing 3d |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
