volume flow rate in a pipe (3D) connected to a tank
Old   April 17, 2018, 04:00
Default volume flow rate in a pipe (3D) connected to a tank
Ahmed Elsayed
bolbol is on a distinguished road
I'm new to Fluent and I'm not sure how to simulate this module
I have a tank full of water with 1 m head connected to a pipe at the exit (1.7 mm diameter & 22 cm length) then connected to another pipe with (1 mm diamter & 10 cm length), the exit at the atm. pressure.
Req: to determine the volume flow rate at the 2nd pipe exit
Right now, I drew only the 2nd pipe, the mesh quality should be good enough
- used Laminar flow (because it's given around 1300 Reynolds no.)
- boundary conditions: pressure inlet (9806 pa) >> equivalent to 1 m headwater
pressure outlet 0 (gauge)
- reference values: Area (0.785398 mm^2)
length (100 mm)
viscosity (0.00089)
pressure and velocity are zero
Are my assumptions correct until now?
bolbol is offline   Reply With Quote
Old   April 25, 2018, 04:19
Ahmed Elsayed
....no one?....
Multiphase flow in a pipe with a CHT wissal CFX 4 June 12, 2017 13:15
How to plot volume flow rate of inlet and outlet in fluent? RueyTeh FLUENT 5 May 12, 2017 21:37
volume flow rate for outlet boundry condition and dfine udf for it raminostadi FLUENT 0 December 24, 2016 02:52
How to calculate phase flow rate? sangramroy FLUENT 0 January 11, 2012 14:02
volume flow rate error in udf jjchristophe Fluent UDF and Scheme Programming 1 July 13, 2010 05:23
