Temperature not converging in counter mixing flow
Old   April 15, 2018, 17:33
Default Temperature not converging in counter mixing flow
Sathish
Sam_1913 is on a distinguished road
Hi guys,
Im simulating a counter mixing flow (water) in which water with 293K (cold inlet) meets hot water (673K of hot inlet) in the middle and then flows down to the outlet. The water region is surrounded by solid steel which is turn surrounded by air. I have set the mass flow rate for both inlets and outflow for the outlet. I have written udf for the water properties namely the density, thermal conductivity, viscosity and specific heat capacity as function of temperature for the given fixed operating pressure of 35MPa.
I started the steady state simulation (hybrid initialisation) using the fixed values of water properties (default setup) and after around 80 iterations, the calculation is completed. Then, i changed the water properties from the constant default values to the udf that i hav previously loaded and ran further iterations, also in steady state. By doing this, i could avoid getting the ''error: segmentation fault''. All the values (velocities, continuiity, k & epsilon) seems to converge after a further 50 iterations except for the temperature which remains plateau ( refer Fig below). furthermore, there are ''temperature limited to XXX'' warning in the consoles once i start running using the udf (refer to fig below). i tried all the solutions discussed in this forum such as setting a lower relaxation factor, refining mesh, set the temp limits to 250 K (min) and 720 K (max), yet there is no improvement...been stuck at this for the past 2 days...hope u guys can share your expertise a bit..the udfs are very simple and i hav attached them in here ( refer below)..im not sure whether its the udf or the solution controls causing this headache...thanks in advance
Sam_1913 is offline   Reply With Quote
Old   April 16, 2018, 12:51
Sathish
Any help would be great...Thanks
convergence failure, counterflow, fluent, temperature limited, udf code
Flow with periodic temperature Florian31 STAR-CCM+ 0 May 28, 2015 05:05
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
Flow Mixing Shyam Main CFD Forum 0 December 28, 2003 14:15
