Splitting Geometry into Multiple Zones
Old   April 13, 2018, 02:55
Default Splitting Geometry into Multiple Zones
Max
max.kozak is on a distinguished road
I am attempting to split my geometry into multiple fluid zones. I will have a fluid zone, a porous zone below that, and then another fluid zone below this one. I cannot seem to figure out how to get this to work. I have completed the blocking for this and created 3 bodies for each zone. I'm then associating the relevant blocks to each respective zone. When I do this, it creates error with the mesh. However, if I just do the meshing all with one body, it is just fine.
Could anyone help me to figure out how I can split up my domain into 3 zones. I thought by adding these material points and then associating blocks with them it would work simply, but that has not been the case
max.kozak is offline   Reply With Quote
Old   April 13, 2018, 05:17
Thumbs up
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
creating material points will not help. Create zone names as required and then assign the blocks to the corresponding zone name and check for face association and assign them if they are wrong.
kiran is offline   Reply With Quote
blocking, icem 17, zone separation
Mirroring / reflecting a geometry in CDF post with multiple planes imanmirzaii ANSYS 0 July 3, 2015 14:44
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Mixing Planes with Multiple Downstream Zones Will Anderson FLUENT 0 November 10, 2010 18:26
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Multiple import of Geometry in GAMBIT(Catcon Simu) Amod kumar FLUENT 0 July 22, 2006 00:55
