Velocity deficit in the wake of a cylinder
Old   April 10, 2018, 18:24
Cool Velocity deficit in the wake of a cylinder
jeremiah
Ocean_engineer is on a distinguished road
I have been running 2d simulations of airflow over a cylinder.
Red=59000
Cylinder diameter = 50.4 cm
Free stream velocity = 20m/s
I am extracting the x-coord,y-coord,u comp, v comp from cfd post and importing into matlab and plotting to compare to experimental data. The velocity profiles are plotted 10D,15D, and 20D downstream.
However, the velocity deficit at the centerline of the wake increases as I move downstream instead of decreasing.
I'm using SSTKO turb model, PISO algorithm, transient simulation with a time step of 1e-4. Yplus value less than 1 etc.
Has anyone run into issues like this before?
Ocean_engineer is offline   Reply With Quote
cylinder, fluent, velocity
Velocity of air coming out of a nozzle attached to a pressurized cylinder LeandroGSS CFX 3 March 6, 2017 18:15
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Wake Region in the TBL mean velocity profile emspinosa Main CFD Forum 2 March 31, 2015 18:27
I need help about velocity vectors direction in cylinder modeling!!! aminepoxnet FLUENT 0 March 17, 2013 18:41
Experimental data from far wake behind a circular cylinder Heini Main CFD Forum 0 October 13, 2011 07:30
