URGENT - Need help in generating mesh interface
Old   April 10, 2018, 07:35
Unhappy URGENT - Need help in generating mesh interface
Naresh Mahendran
nareshzeeda1994 is on a distinguished road
Hi all...
I need help to generate the mesh interface between surfaces.
I'm doing heat transfer analysis of 2 heat exchanger by placing it under a domain.
The flow of primary fluid ( air ) is in same direction for all heat exchanger whereas for secondary fluid ( coolant ) differs.
I have attached pictures regarding the geometry.
Air flows in -Z axis while coolant flows in -Y axis ( 1st heat exchanger ) & X axis ( 2nd heat exchanger ).
Please help me in giving mesh interface. Because i'm getting floatation point error.
Thanks in advance.
nareshzeeda1994 is offline   Reply With Quote
Old   April 10, 2018, 09:23
Thumbs up
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
modify the air domain to the extent of inlets and outlets of both the heat exchangers. Side walls surfaces should be in line (both surfaces in same plane) with inlets and and outlets of heat exchangers.
kiran is offline   Reply With Quote
Old   April 10, 2018, 11:15
Naresh Mahendran
Thanks Mr.kiran..
Since i'm new to ansys, can you help me in doing interface ?
Please send me your mail id. I will send you the file.
Old   April 11, 2018, 02:10
kiran Ambilpur
make the boundary/domain as shown in the attached image, I have drawn those line assuming it as a top view.
Old   April 19, 2018, 07:35
Naresh Mahendran
Should i make it as a single part or multi parts ( HX1, HX2, domain ) ??
Old   April 19, 2018, 09:17
kiran Ambilpur
yes, you need to make three.
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Frozen Rotor 1:1 Mesh Connection pharley CFX 5 January 31, 2013 17:15
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
