Urgent HELP PLZ: how to make Porous Jump (B.C.) in 3D
Old   April 10, 2018, 03:48
Exclamation Urgent HELP PLZ: how to make Porous Jump (B.C.) in 3D
Payar Radfar
PayarRadfar is on a distinguished road
Hi Guys,
I am struggling with making a 3D Porous Jump Boundary condition. In 2D I used just draw a line/edge in my pipe and then use the "fill" function in design modeler on the edge and the pipe face (fluid Domain) and Ansys meshing use to not mesh that and take the common nodes. Later on in Fluent i used to set the B.C. as porous jump and everything worked perfect.
Now for 3D I understand that I need to make a face rather than a line, which I do but fill option in unavailable and meshing does not recognise it and fluent also doesnt even show that in the boundary conditions (Even though I named it correctly).
Could someone explain what I need to do for 3D B.C. of Porous jump?
Best Regards
Payar Radfar
Payar.Radfar@gmail.com
PayarRadfar is offline   Reply With Quote
Old   April 10, 2018, 04:16
Payar Radfar
As I was reading online, My only difficulty is how to make fluent understand an internal face/ Interior boundary
Best Regards
Payar Radfar
Old   April 10, 2018, 23:41
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Payar,
As per my knowledge, for 3D case - make the porous body as separate body. Later on, under cell zone conditions, choose the respective body and define porous zone. If the body doesn't lie perpendicular to the axis, use plane tool options to define direction vectors normal to the plane..
For more than one body in a domain, interface will be automatically created, where you can define porous jump condition. If just one body, name the boundary condition as porous jump on particular face rather than creating a surface and give a try..
Thank you
Kummi is offline   Reply With Quote
boundary condition, designmodeler, porous jump
Am i right? porous jump drag force Shim FLUENT 2 August 25, 2014 10:33
Porous jump boundary condition egge24 FLUENT 1 October 20, 2012 14:30
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
About porous jump B.C. Susan FLUENT 0 June 14, 2007 05:31
Porous Jump Naresh FLUENT 0 April 25, 2007 16:36
