help with udf for wind profil at inlet
Old   April 8, 2018, 10:44
Default help with udf for wind profil at inlet
BEKRAOUI Adil
BEK_Ad is on a distinguished road
hi;
i'm a beginner with udf at fluent.
i try to modify the tutorial on velocity profil at inlet that cames with fluent documentation.
this is the code (i just changed the equation)
vprofile.c
UDF for specifying steady-state velocity profile boundary condition
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, position) = 2. - (y-84)*(y-84)/(84*84)*2.;
end_f_loop(f, thread)
when i compile and execute, the solution diverges. and when i try to initialize from the inlet i have X Velocity=8674757m/s
i even tried to put F_PROFILE(f, thread, position) = 2. but i have always the same error.
the geometry is a 3D square with dimentions :
H=84m --> Y axis
L=100m --> X axis
W=2 m --> Z axis
tank you
BEK_Ad is offline   Reply With Quote
Old   April 8, 2018, 11:08
Default solved
BEKRAOUI Adil
sorry
i found that fluent was pointing to the wrong .c file
fluent - udf, fluent 6.3.26, wind profile
Disappearing mass when using udf inlet profile divergence Fluent UDF and Scheme Programming 5 January 2, 2021 15:56
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
UDF for inlet velocity alongwith UDF for properties akshayy224 FLUENT 0 February 1, 2018 10:17
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Probleme to interpret 3D temperature profil UDF christophe06 Fluent UDF and Scheme Programming 4 February 20, 2012 09:06
