April 4, 2018, 02:25 |
FLUENT > CFD-POST Data Transfer Problem
CT
Rep Power: 10 |
Hi All!
I am trying to simulate external flow analysis on Fluent. But when I try to open results on CFD-post and check force values, there is a huge difference between Fluent and Post. I get drag values i.e. 700 N on Fluent but CFD-Post give me at least 300k N. This problem appears only force values, wall-shear values. But I checked velocity values and there is no problem with it. Seems ok. What is the problem? Am I miss something? Thank you for help. Kindly Regards. |
April 6, 2018, 02:17 |
#2 | |
Payar Radfar
Rep Power: 8 |
I dont have access to ANSYS now but in fluent you can either export files from file -> export or just before solving going to the report and i believe there is an export option where you tell FLUENT what output values you want and what format. Hope that Helps |
ansys, cfd-post, fluent, post procesing |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 07:23 |
Problem regarding producing streamlines from surfaces in Ansys CFD post | gauthamnarayan | Visualization & Post-Processing | 0 | April 23, 2015 16:07 |
Problem in sampling data of custom field function in ANSYS FLUENT v14 | apek_great | ANSYS | 1 | February 26, 2014 05:10 |
Problem Accessing Obscure Data Variables in Fluent | randomPhil | Fluent UDF and Scheme Programming | 3 | December 12, 2013 11:42 |
Data Transfer - Polyflow to Fluent to Abaqus | Bob Carson | FLUENT | 0 | March 27, 2007 09:31 |
