Hello guys. I am doing my simulation on a 2D shallow depth combustion chamber
Old   March 31, 2018, 16:49
Default Hello guys. I am doing my simulation on a 2D shallow depth combustion chamber
Momen
Mr fitness is on a distinguished road
Hello guys!
I am doing a simulation on a 2D shallow depth combustion chamber.
I am struggling on some points as I am not familiar with the program so well.
first of all, my general set ups are transient, axisymmetric 2D, pressure.
My bc are so simple and there is no inlet nor outlet.
Only axis, cylinder head, piston ring and walls.
It was set to fluid, is that correct?
Secondly, when I upload my iso-octane chemkin format, it shows error in species line 139, how do I know the number of the line and how do I fix it?
Moreover, for the dynamic mesh, ansys fluent creates new bc such as interior body do I set it in the dynamic mesh as i am interested in in cylinder? And what do you think my boundary condition should be like walls?are they deforming, stationary or rigid? And for the piston ring, cylinder head and the axis?
And the cell height problem. It usually gives me this error
Error at node0. Negative cell volume detected.
Error at node n, whatever the number is but they all got the same error?
Any idea? I usually set my cell height based on the size of the element that I have sized in the mesh? Is it correcr or ?
And for the simulation of the combustion chamber, am I supposed to make a notepad.prof file for the motion of the piston?
If yes how?
Thanks in advance, hope I get ahelp as I need to submit the validation of this study in a month.
Thanks again guys. Ill appreciate your reply.
Mr fitness is offline   Reply With Quote
Combustion Chamber Species Transport Catthan FLUENT 2 April 27, 2021 04:39
gas turbine combustion chamber cold flow simulation chawane FLUENT 1 January 21, 2016 11:56
Having problems setting up boundary conditions for paint chamber simulation shigua FLUENT 0 December 3, 2014 11:26
Not burn in Two Step Simulation of A Combustion Chamber Modest Cat FLUENT 2 December 5, 2011 05:06
I need design planes of combustion chamber HITACHI GE AdidaKK Main CFD Forum 0 July 2, 2009 15:04
