Average torque in transient vawt simulation
Old   March 29, 2018, 06:53
Default Average torque in transient vawt simulation
Patryk
FeveR is on a distinguished road
Dear users,
I'm simulating flow around 3 blades, vertical axis wind turbine (2D) for my master thesis using sliding mesh method. I have done 200 timesteps with 0,005s time step size which give 5s of real time simulation. My results looks really fine, but I need to know average torque over rotation axis (Z) on all blades of the turbine in that 5 seconds and I don't know how to calculate it. Value of torque is different in every timestep. Is it possible to export torque from all timesteps to excel and then calculate average of it ?
I tried to plot Momentum during the simulation (Solution -> Report Definitions -> Force Report -> Moment), and than select blades and Z axis, but values on that plot is always less than 1, so it looks like Cm, not really torque. When i calculate torque using CFD-Post calculator the values at any timestep looks fine. Thanks for help. Sorry for my english..
FeveR is offline   Reply With Quote
Old   March 30, 2018, 08:33
Patryk
Please help. I'm stuck here because I can't compare my cases
Old   March 31, 2018, 12:04
Patryk
Ok, problem solved.. if anybody else facing it, there is a solution :
You need to print a Cm plot (like I wrote in 1st post) and write this values to a file. Then export this file to excel and count torque using this formula for every timestep :
Cm = \frac{M}{\frac{1}{2}\rho v^{2}AL}
where M - torque, V - stream velocity, A - Area, L - lenght (rho, A, L in 'reference Value tab')
Finally, just do the average of all torque values.
Old   December 20, 2019, 12:03
Nguyễn Tài Đức
AerospaceVN is on a distinguished road
dear feveR
I am simulating a VAWT like you. Can I ask some question about moment and moment coefficient
When you set up the solution, did you set the reference value? what reference values you set?
I set Area = wing area, lenght = radius, velocity = wind speed
the moment coefficient is very low according to my calculations.
hope you share your experience
thank you
AerospaceVN is offline   Reply With Quote
2d simulation, average, torque, transient, vawt
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
VAWT simulation rotation domain steve20024 Main CFD Forum 0 March 2, 2015 04:37
Steady Simulation of VAWT steve20024 Main CFD Forum 4 November 27, 2014 06:02
Resume Transient simulation HMR CFX 1 June 28, 2011 22:13
How obtain the average of lift over time for a transient simulation? aero ANSYS 0 November 11, 2009 03:00
